Old 01-09-06, 03:19 PM
DF3AV
Question new boots
Hi there!
I am looking for a set of boots for our Skymaster Reims F337F.
It has 2 Boots on each wing plus one one the stabilizer.
Is there something somwhere to find?
Buying new is a little bit too expensive (abt $10.000).
Would rip off the boots instead.
Reinhard
Old 01-09-06, 05:50 PM
The problem is exactly as you describe it.
In removing the old boots, you rip them off. They can't be reused, because of the removal. As a result, used boots don't exist. New boots do exist, they are expensive. There are methods used to refurbish, repair boots, that allow you to continue to use them. There also comes a time when that no longer works.
There are weeping wing (TKS) de-ice systems used by other planes, and electric de-ice used by someone, but neither is availble for the skymaster. It would, in the United States, require an STC, which is an expensive process.
Old 01-10-06, 02:31 AM
DF3AV
Anyway, it seems to be an expensive issue to replace these boots.
I think, there should be some skymaster owner out there which should refurbish their boots but donŽt do it - like me because of the costs.
What would be, if weŽll order all together lets say 10 sets of boots. I am quite shure, the price will go down drastically because most of the labor costs will be payed for the setup of the tools - not for making the boots.
The question then is: how many sets of boots are required?
Which kind are they (one pair each wing, or conventional)?
Please write a message to this thread if you expect new boots for your skymaster. Thereafter we know the number and can go into contact with the manufacturer to negotiate.
When a price is settled, each potential Skymasterowner can decide to do or not to do (that means, any post here is NOT an order!)
Best regards
Reinhard
