Unread 01-03-04, 01:44 PM
Master & Ground Solenoid
I am having some small electrical problems which I think may be due to excessive resistance in electrical lines to the landing gear electrical motor, probably in the master solenoid. Many of you recall that GMAs, among others, recommends that the solenoid be changed every 3-5 years. My problem is this: when I go to get the part number, there seems to be`two, one for the battery and one for the ground. Now Í am clueless. I know that there is one for each engine starter, and then there is the master or battery solenoid mounted on the firewall near the other two, so what is this other one, a ground solenoid or contactor? What does it do? Can anyone help? The P/N I have for the battery solenoid (which I think is the master solenoid) is S1580-1 and the ground solenoid is S1577-1. Should I change both?
Unread 01-03-04, 07:01 PM
i had the same problem several years ago, replaced all four of them (one for each starter, master and for the gear) got them through a cessna oh shop). if my memory serves me correct thay are all identical and less than fourty bucks ea. sorry not much help without a parts book.
Unread 01-03-04, 11:30 PM
Solenoids
You should have a battery or master solenoid and a solenoid for ground power which is mounted under the battery and the 2 starter solenoids. The master and ground power solenoids have a continous rating and the starter solenoids have a intermittant ratings thus the different P/N's
Hope this helps
Kim
Unread 01-08-04, 06:07 AM
Thanks, Kim. Could not figure out how there could be a solenoid for the ground (as opposed to "hot") side of the electrical circuit, since I knew that the minus post of the battery is hard-wired to frame. Now I know what they mean by "ground". Bought the battery solenoid by phone from Yingling and will install when it gets to Miami (I´m still in Europe).
Hope to see you at this year´s meeting.
Unread 01-08-04, 08:11 AM
Ernie, if you are in England or near enough to me near Stratford, please give me a call and I will buy you a beer.
Unread 01-09-04, 10:56 AM
Thanks, Dave, but I´m in Spain and going home (Miami) tomorrow. Next time.
Unread 01-13-04, 12:17 AM
337 Battery and Starter Solenoids
Ernie, give me a call. I have new starter and battery solenoids for sale and they are different.
Don Nieser
Commodore Aerospace Corp
6221 Commodore lane
Oklahoma City OK 73162
405-722-4079 phone and FAX
405-503-4686 hangar cell phone
Unread 01-13-04, 08:40 PM
Good to know, Don, but I was in Europe at the time and ended up buying new from Yingling. Next time.
Regards,
