Thread Tools |
Rating:
Display Modes |
Impossible Mission: Inverter Power Transformer needed
Hi Folks,
I have an old Bendix inverter in my '73 P337 that drives my RMI and also the heading synchro for my Stormscope. I am looking for the power transformer used in this inverter. I do not have schematics for the inverter, so I don't know the characteristics of the transformer. Any help anyone can provide in finding either a transformer, or a place that has parts and will repair or exchange the inverter would be much appreciated. If I can't economically repair this unit, I will have to replace it with a low power (peanut) inverter, and dump the RMI in favor of a stock ADF indicator for my KR-85 ADF. This would not be a tragedy, but I find that out west here, and in Canada, I still need my ADF frequently enough to make spending some small amount of money worthwhile. The unit is a Bendix PS-815A, part number 4000289-8503. I believe I need an inverter rated at 15 amp or more to replace it, because the KI-226 RMI rated draw is 13 amps. The power transformer part number is 17325-1. I don't know if that is a Bendix part number, or another manufacturer. There is no other nomenclature on the part. Thanks for your help. Kevin |
Hi Kevin
Gary Wedding in Eloy Arizona has a warehouse full of stuff. I just talked to Dad in Mesa and gave him all the info. He is going to see what he find for you. I will get you a telephone number for Gary also Frank |
Super Frank! Thanks... -Kevin
Kevin,
Don't take the RMI off life support yet. I love mine. Two weeks ago I went into Nanimo, BC. Lowest approach available is an NDB-DME. NDB alone gets you to 900, with DME you can go to 720. The DME stands alone, not associated with a localizer. There is no GPS overlay. Coming and going, it is a busy couple of minutes and the RMI makes it dirt simple. Mine's a KR 87 with a KI 229 head. Bawb |
Do I like my RMI? Absolutely. But it is a KI-226 (old). It draws a lot of current, and has become "sticky" lately. It may be the thing that burnt up the inverter. If I can repair the inverter, I'll have the 226 bench tested and if it passes, I'll put it all back in. If I can't repair the inverter, well, I am not sure I like my RMI well enough to spend nearly a grand on an inverter that will support it, versus $350 for an inverter that will support only my stormscope heading slave. If the 226 is truly sick, it would be another $500 to replace it with similar used unit (I don't like to think about what a new one would cost). In the end, with a small inverter for $350 and a stock KR85 head (manual card) for $100 or so, I can still do your ADF-DME approach, it will just be more work. I'd rather put the extra money away for future maintenance, or towards an approach approved GPS.
Anyway, I am hoping that a miracle happens, and somebody can suggest where I can get parts for my Bendix inverter... Kevin |
Hi Kevin
Gary Wedding 's telephone # 520 466-4181 I looked up Eloy area code is 520 not 928 Frank Last edited by Frank Benvin : 03-13-03 at 08:24 PM. |
Thanks Frank, but that does not seem to be a working number. Area code is for Arizona, but there is no 466 prefix in 928 area code... Maybe somebody transposed a number along the line?
Thanks for trying to help. Kevin |
N358 1967 337B Normally Aspirated, KX155, Mod "C", Cessna Auto Pilot 400, 4 Seats, 3400 TT on Airframe |
| Thread Tools | |
