Unread 12-01-20, 10:32 AM
Skymasterdriver Skymasterdriver is offline
Skymasterdriver is on a distinguished road
Front and rear engines and props
Getting ready to install new engines, props and instruments.
Would like to sell old parts as a package.
I haven’t removed the old ones yet but if there is any interest in these let me know.
Western skyways charge $14000 for cores
Used props and Spinners and backing plates are getting hard to find
Would take $30000 for it all
Engines x 2
Props x 2
Engine instruments cluster
Unread 12-01-20, 09:01 PM
Bert
What’s the details on the engines and props? Time, age, condition, etc
Unread 12-02-20, 02:28 PM
JimC's Avatar
JimC JimC is offline
Wait - you bought new engines from someone who didn't give you core credit? Where did you get them?
1969 T337E
Unread 12-03-20, 04:22 PM
Front engine
1888.7 smoh
Prop
1612.8 soh
7-20-99
Rear motor
1797.2 smoh
Prop
1613.3 soh
2000
Unread 12-03-20, 04:40 PM
Bought new overhaul engines outright from a private person that had them overhauled and didn’t us them.
Here’s the story all my old engines props and gages run very well and decided to keep running them until something showed a problem that would make me decide to change them, a few weeks ago I walked past my front prop and one of the blades had a greater angle than the other, called the prop shop and they said there is a wooden block that controls the pitch of the blades and they fail from time to time, $ 1000 fixes the block and gets you a reseal job, however there is a little corrosion showing on the outside surface of the hub and has suggested that I should look for a new hub sometime in the future, but no big deal he would reassemble it and it would be fine for me to finish out my engines with it, I told him to see what a new hub would cost and maybe we would just fix it right, then he all the sudden they decided maybe he wouldn’t put it back together( seen a bigger sale) so now it doesn’t make any sense to put new props on old engines, so I’m putting on new MT props, engines and didn’t want to run new engines without all cylinder monitors so mvp 50s it is, all old parts for sale props engines gages
Unread 02-03-21, 02:17 PM
rbose rbose is offline
rbose is on a distinguished road
Are these IO-360-Gs or GBs? VAR cranks?
Unread 02-03-21, 03:54 PM
Io360g overhauled in 89 so I don’t think they have var Crank’s
Unread 09-07-21, 11:31 PM
GregW GregW is offline
GregW is on a distinguished road
Are any of the engines still available?
Unread 09-08-21, 05:52 PM
They both are, haven’t been trying to sell them thinking of keeping them, but if they can be of use for someone then I would rather see them running instead of sitting.
Unread 09-09-21, 02:21 PM
I have a 1965 skymaster. I am not ready for engines yet however I want to have an engine ready to go when it’s time to avoid downtime. I have not talked to my mechanic yet but assume your motor will work on my plane. I would just need to overhaul it then it would be ready to go. Any thoughts or words of wisdom? Also it looks like you did mt props. What can you tell me about them. Do you like them? Can you do one and not the other? What is expense? Just curious as I want to have a prop ready to go as well
Thanks Greg
Unread 09-10-21, 01:59 PM
Io360g is what I have
Have not gotten my new engines on yet so don’t know if I like the Mt props
Unread 09-10-21, 09:12 PM
Ok thanks. So your motors have 2k hrs and they have been overhauled once? Let me know if you get your new motors on and are selling those
Unread 10-04-21, 02:16 PM
They are both off I just haven’t got the new ones on yet do to putting mvp50 in and new engine control cables, the build process is going slow. But all the old stuff is out of the plane
Unread 10-04-21, 04:50 PM
I have a 1965 skymaster. The rear motor has 1400 hrs. To avoid downtime I am looking for a motor to redo and have sitting on the shelf ready to go when it’s time. Possibly same idea for prop. What are you asking and what can you tell me about the motors? You can email directly at wilsongregoryscott@gmail.com. Thanks Greg
Unread 01-31-22, 09:40 PM
Alanw Alanw is offline
Alanw is on a distinguished road
I’m looking for engine probes if either engine had them.
