Unread 04-24-20, 05:11 PM
Pitot Heat unit/alternate
It looks like getting the thermostat/heater unit for the pitot heat is a very challenging thing. I'm not having much luck and ours keeps popping the CB every time it's turned on.
Does anyone know where I can get one or an approved alternative I could install?
Tripp
File Type: jpg 60926675269__29A3F311-8580-4FE7-916A-3F7D13317996 (1).JPG (481.8 KB, 2864 views)
Unread 04-27-20, 10:22 AM
Check all the connections as that will sometimes be the problem. I know Griswold Aviation has fixed several of these but can't remember where he sent them. Give Craig a call 269-330-2908
Unread 04-27-20, 12:56 PM
you can get the therostat from air power $43.00 P/N 430-863
Unread 04-28-20, 10:33 AM
I've checked all the wiring and connections and it's definitely not that. I'll give air power a call.
Unread 04-28-20, 11:50 AM
if the thermostat wasn't properly bonded to the pitot block I would suspect the heat pad is fried I would try ohming that
Kim
Unread 04-29-20, 07:34 PM
Still working on the element, it is wired in series with the thermostat. The thermostat should be bonded to the bottom of the pitot, it appears you heater is missing in the circuit.
Dan
Unread 04-30-20, 02:37 PM
So apparently someone in the past glued the heat blanket to the inside of the strut fairing. That is where it is now. It's also probably why when I test the thermostat only it pops the breaker because nothing is going through the heat blanket.
I'm hoping to maybe just find an entire pitot unit with the heating elements I can replace this with, but all help and suggestions are appreciated. I've called everyone that's been suggested to me with no real luck.
Unread 05-02-20, 10:14 PM
Gord Tessier's Avatar
Pitot Heater
Recommend, You dig it out and reattach it to the block. The installation calls for a bead of RTV to be put on it so it sticks to the inside of the fairing with no air gaps. The photos seems to indicate the pad is out of the circuit. It needs ot be in the circuit or the thermostat will likely pop. The pad itself does degrade with time. I was able to buy one of the last remaning ones. I found it on Controller using the part number for the heating pad.
Best of luck!
Gord
C-FTES
Unread 05-04-20, 10:28 AM
Gord,
Thanks for the info. I hope this helps. I'm passing this on to my avionics tech to do now.
Tripp
Unread 03-16-21, 03:41 PM
Thumbs up
Installed mine, plus thermostat, over the weekend--Ops Check good and my A&P/IA team is impressed with the kit package and written instructions. Well done, Dan! 5/5 would recommend.
Unread 03-16-21, 09:26 PM
Glad it worked for you!!
Dan
Unread 03-16-21, 10:58 PM
Good to hear jetter! I have one of Dan's kits in my growing spares cabinet, just in case...
