Unread 10-02-09, 07:23 PM
rod donner rod donner is offline
rod donner is on a distinguished road
alternators
Help
I have a 1973 Press. 337 that when descending from alt.{airspeed a little higher{} the front alternator out light comes on. However when I turn off the rear alt. the light for the front goes off. conclussion; even now when I am in level flight the front alt. out light comes on intermittenly, if I shut of the rear alt. the light for the fromt alt. goes out, or if I load up the elect. system, for example turn on all elect. including landing lights,then front and rear light stays off. this is a two regulator system, I checked the front alt. by trying to turn it using cooling fan, cant do it . any ideas, thanks ;
thanks for the clue on the gas gauge, there was corrosion in the plug at the wing root. this is an awesome information center.
Rod Donner
Unread 10-03-09, 12:22 PM
Tony
It sounds to me like your regulators need to be adjusted. S/N 1399 and on are different from the older models in that instead of one regulator running 2 alt. each alt. uses one regulator. Check the voltage output from each alt. separately. It should be 27.5 +/- .2 volts. with landing light on. If they are out of adjustment, one will kick the other offline.
This was a common problem with some of the C402's I used to work on.
Unread 10-04-09, 03:00 PM
Originally Posted by rod donner View Post
Help
Rod Donner
Had the exact situation you describe some time ago. Usually in cruise an alt. (Front I believe) would drop off and stay off till voltage dropped some then would come back on and stay on for a good while till it repeated the process mabey on the next flite. Anyway its a 73 G model like yours and we finally adjusted the alt like was mentioned in the previous post and the problem hasnt come back. I wouldnt ignore this as I believe it caused an alt faliure for me.I believe that the alt is cycling under full power and that cant be good.
