Old 05-01-05, 07:24 AM
skymastp skymastp is offline
skymastp is an unknown quantity at this point
Cowl flaps motor
I got back Cowl Flap(front) motor that has been O/H from shop,
after inst. on aircraft, only works one way (only open not
close) where should I check next? 1965 337
motor works fine(open or close) before it quit( I thought only motor need to be service)
Jared
Old 05-01-05, 02:32 PM
Have a look at the Micro switches on the motor drive shalf, you will more than likely find a switch bad or a wire off.
Pete
Old 05-02-05, 07:00 AM
Thank You Pete
Pete Thanks
I will check M/Switch
Jared
Old 05-06-05, 07:16 AM
Pete Thanks
Pete thanks
I checked Wire and M/c switchs on behind panel and find "loose wire" my motor works fine again
Jared
Old 05-06-05, 08:44 AM
Mechanic @ TOA
Pete:
If you need a mechanic, Tom McCrea at Southwest Air Services in Torrance did my work when I was based there 8-9 years ago.
I know he still operates on the field, as I visited with him over the Holiday season.
Rick
