Unread 11-14-22, 04:59 PM
Alainb Alainb is offline
Alainb is on a distinguished road
door seal for FT337GP 1975
Hello
I am looking for a door seal for a Cessna FT337GP 1975
Any tips ?
Alain
Alain
+41 79 266 2000
www.evazion.ch
www.osud.ch
www.Whitepod.com
www.purplewings.ch
Unread 11-14-22, 09:49 PM
https://aerocessories.aero/
These are the ones that Riley used. The ultimate electric for the C210 is probably what you want but you could go with the manual inflatable, it's a lot less money. It doesn't say C337 but you need to compare the length and find the closest size that will work. These are great seals and work really good.
Unread 11-14-22, 11:25 PM
door seal
Hello
Thanks so much for you answer. I will look at it.
So glad to be able to have all your great advises guys...
Alain
Alain
+41 79 266 2000
www.evazion.ch
www.osud.ch
www.Whitepod.com
www.purplewings.ch
Unread 11-14-22, 11:49 PM
Manuel door seal
Hello
I look at the link. What do you think about the manuel pumped door seal ?
Alain
Alain
+41 79 266 2000
www.evazion.ch
www.osud.ch
www.Whitepod.com
www.purplewings.ch
Unread 11-15-22, 02:41 PM
Check your seal now as I see you are referring to the Reims Pressurized Skymaster
If it is not inflatable then the manual inflatable seal should be a good option
I have one on my NA Skymaster with one door (not clamshell door) and it works great
Unread 11-16-22, 04:51 PM
Hi Alainb,
I also have a (Reims) Pressurized Skymaster. Our seals inflate with cabin pressure, once the cabin starts to pressurize.
If your seal is repairable, there are instructions for repair in Chapter 16, Section 37 of the Maintenance Manual.
Hope this helps.
Rick
N337K-FT337GP
KLOU
