Unread 11-27-20, 01:25 PM
Anyone have EI CGR engine instruments?
We are looking at replacing our engine instruments with the EI CGR TWIN PRIMARY PREMIUM package. We will do a field approval since it's not on the list. Wondering if anyone else has already done this? If so, any chance you have a picture of it installed and/or the Field approval? It would be greatly appreciated.
Tripp
Unread 11-28-20, 01:14 AM
I opted for the EI-MVP50P, if you want a pic that install, let me know.
Rick
N337K-FT337GP
KLOU
Unread 11-28-20, 12:55 PM
If you have a photo easily available I’d love to see it.
Thanks.
Unread 11-28-20, 04:21 PM
Here ya go ...
https://1drv.ms/u/s!Apiok8NRRsL6nMc3qYVHrYeFFCddPg
N337K-FT337GP
KLOU
Unread 11-29-20, 10:33 AM
JimC's Avatar
JimC JimC is offline
Nice!
The upper one has an "unsafe" light and the lower has a hydraulic pump light.
How are those connected? I'd guess your unsafe light would be extinguished if you're on the ground.
1969 T337E
Unread 11-29-20, 02:56 PM
The "HYD PUMP" light indicates when there is power being applied to the pump motor. If the amber gear up light or the green gear down light is illuminated and the hydraulic pump is energized, the gear doors are open (or in transit).
I still have a couple configuration issues to work out, this is one of them. Yes, the "UNSAFE" light should be extinguished when on the ground. The "UNSAFE" light will illuminate when either of the throttles are retarded with the gear not down, or when there is no power on either the gear up or the gear down panel indicator lights (or gear is in transit).
This is a picture of the System pages of the MVP displays. System pages for the MVP-50P
There are gear down and locked annunciators for nose gear and right gear. Since they are wired in series (nose, right, left) to get to the green down and locked light on the panel, I will be able to see downline as far as the circuit is completed.
Since you are looking at the CGR-30, here is a picture of a CGR-30 install in a friend's C-340.
EI-CGR30 installation in a C-340
N337K-FT337GP
KLOU
