Unread 03-31-04, 07:41 PM
rubber window gasket
73p
does anyone know a source where to purchase the rubber moulding that holds the plexyglass in place, mine has shrunk leaving a 11/2 gap and is starting to crack.
thank you - rick
Unread 04-06-04, 12:30 AM
SkyKing SkyKing is offline
Rick,
Cessna has the item... refer to your Parts Manual for the Cabin Interior parts. Once you have the part numbers, you should be able to look it up on-line at these two sources:
http://www.iwantcessnaparts.com/
http://www.cessnaparts.com/
I recall this item being fairly reasonable.
SkyKing
Unread 04-07-04, 10:01 PM
We just got @25 ft. from yingling. can't remember the cost, but I don't remember pitchin a hissy when we got the bill.
Unread 04-16-04, 02:14 PM
thank you kim, e'd them under 5 per ft.
Unread 04-19-04, 05:41 AM
I recently got some from Browns Aircraft Supply in Jacksonville (904)396-6655. He has S2171-1 which does most of the windows and the price was pretty good in comparison to everyone else.
On the door windows, you need S2171-1 plus the S2172-1 molding, which I have not been able to located easily. Please let me know if you find a source for it.
If anyone has figued out a good way of joining the ends, please let me know. Otherwise the job is not as good as I woudl like to see it.
Unread 02-28-21, 03:50 PM
I’m resurrecting this 17 year old thread because I need this seal.
The Cessna part number is S2172-1, but it was superseded by part number R581567, ... which is no longer available.
Does anyone know of a supplier for this window seal?
If not, how about another sponge rubber seal that has a profile similar enough to work?
Rick
N337K-FT337GP
KLOU
Unread 02-28-21, 04:47 PM
TomM's Avatar
TomM TomM is offline
Great Lakes Aero
I just had my pilot side windows and door window replaced at my annual and my mechanic got the plastic and the seals at Great Lakes Aero.
Unread 02-28-21, 04:49 PM
Thanks Tom, is your plane a P model??
N337K-FT337GP
KLOU
Unread 02-28-21, 05:08 PM
TomM's Avatar
No it is not. They may still have stuff for the pressurized model, so I would check them out. The other company that people get windows from is LP Aero Plastics.
