Old 12-17-20, 06:07 PM
Jhogan0101's Avatar
Scat tube routing around rudder controls
Anyone have any photos of some tidy routing?
My pilot side one is currently zip tied to the rudder pedal torque tube.
Im sure there is a better way to do this.
337B
Philadelphia PA
Old 12-23-20, 07:44 PM
Will send pics tomorrow.
Old 12-24-20, 10:59 PM
I have that area apart right now for some brake work. There is a duct that runs vertically from heat duct to defroster outlet. With no excess slack it is not able to get over that far. Pretty much a straight shot. Is this what you’re talking about? Maybe your duct is too long. Perhaps check the parts manual for your model. Might give a drawing of how things are supposed to be.
Old 12-25-20, 01:18 PM
Jhogan0101's Avatar
This is both sides here, just doesnt seem like a great way to run these.
Nothing in service/parts manual about it.
Just wondering if someone else figured out a better/neater way to do this.
https://ibb.co/YXFWmMw
https://ibb.co/Bwd4gpN
337B
Philadelphia PA
Old 12-27-20, 08:35 PM
I have attached photos of my routing of the defroster tube and scat ducting. At least I hope I have successfully attached the photos. If not, basically the scat tubing goes behind the crossover linkage/bar for the rudder pedals and brakes straight up to defroster duct. I have a rigid tube that runs behind the crossover linkage but it is same diameter as scat tubing so scat tubing should be able to made to work.
