Old 10-11-20, 05:58 PM
Nosegear actuator
While servicing strut noticed small leak in nosegear actuator. Removed it and sent it out for overhaul. Overhaul shop advised needed pins that engage the hook replaced. Same issue as service bulletin for cessna 210, 100 and 200 series retractable aircraft. Old style pin that the hook engages (which holds your gear in the down and locked position) is subject to fracture/failure. There is a new style pin to put in place. Also the spring that is part of the locking mechanism has a guide inside of it. Original guide plastic and if fails, spring can fall out, mechanism doesn't stay locked and nosegear will fold on you (also like 210). Amazingly I had the original 50 yr old plastic guide in place. Like the rest of the plastic I'm sure it wasn't long till it gave out. Something worth looking at. Had everything done. Good piece of mind.
Old 10-11-20, 07:47 PM
Where did you source the parts/repair
Old 10-12-20, 12:31 AM
Sent the cylinder to Cox Airparts in Wichita. They did the overhaul pins and everything and bench tested before sending back. I asked before sending my cylinder to them if they wanted the hook/pin mechanism to come with the cylinder and they said yes, to test it. Once it got there they advised about the pin issue. Although I sent it for a leak/overhaul, while they had it they updated the hook pin mechanism. Very happy with them.
I was suspicious about my plastic spring guide, that plastic was in such a critical area, and questioned it's age/integrity. Discovered the spring guide issue while combing old Cessna Pilots Association articles where John Frank wrote about it on cessna 210's. I then found service letter for 337's advising the updated steel spring guide.
Old 10-12-20, 06:02 PM
What is the service letter number? We're not supposed to post copies of Cessna's SLs, but that doesn't mean we can't link to their site where they have them posted.
Old 10-13-20, 07:38 AM
Oh yeah, that's right not supposed to post service letters on the site.
Regarding the spring guide: it is what was then titled "Multiengine Customer Care Service Information Letter" or "Multiengine Service Letter" dated Jan 13, 1984, number ME84-1. Specifically for the 337 announcing the new steel guide and superceded part number.
Old 10-14-20, 02:10 AM
The pin you mentioned was also plastic. The new pins are metal. Unbelievable Cessna thought that was a good idea.
Old 10-14-20, 12:23 PM
Question Can't find this Service Letter
I'm interested to read this, but I cannot find it anywhere, even on the Cessna Support docs directory page. Its as if it never existed.
If anyone can point to where this Service letter can be found, it would be greatly appreciated.
Old 10-15-20, 01:08 PM
https://ww2.txtav.com/TechnicalPubli...Number=ME84-01
You'll probably have to have an account to access.
In a nutshell, the SL announces the availability of the new part, P/N 9882024-1, and says to install with reference to the service manual. List price is $68.14, $61.33 from Yingling.
