Unread 09-02-19, 08:02 AM
YankeeClipper's Avatar
How are sales transactions typically done these days?
How, in this modern age, are transactions carried through once the price is agreed upon? My thought was to:
  • agree to these steps 1st
  • establish payment method (Venmo or bank wire depending on limits )
  • meet for transaction at the plane
  • do a final inspection akin to home sale (nothing changed, missing, etc since PPI, no glaring oversight by inspecting A&P... )
  • Am I expected to fly it myself?
  • fill and sign sales documents
  • wire money
  • shake, and carefully observe for larger of two grins
  • fly (hopefully)
I suppose I should add: round out top of wallet, aim toward local A&P, and rotate. But that's implied. Does the rest seem about right?
Unread 09-02-19, 12:29 PM
In this scenario, has an aircraft history been requested from the FAA? That might reveal things that could surprise the owner, since it's not unusual for paperwork to disappear over the years. It's cheap enough that it should be the first step if a potential buyer is at all serious about purchasing the airplane.
https://www.faa.gov/licenses_certifi...craft_records/
How about a title search? The aircraft history should contain all lien records, but often doesn't. AOPA can do that.
Unread 09-02-19, 10:25 PM
Here's my opinion on this
If you can work with a broker that you trust he will represent your interests. Use a broker that has been down this road before, has experience and is referred by some on you trust.
Pre-Inspection should be partnered with a knowledgeable aviation expert. Could be your broker, an A&P or someone that knows airplane like your seeking. You need to stay as neutral as you can and be careful not to let your emotions drive the deal. That's where the accountability of another person comes in. They look from the outside in with no interest in the plane. If the initial inspection (not a pre-buy) passes then you dive into Log books. That's where the A&P knowledge takes control. It may be that you have the logs scanned and sent to your A&P that you trust. Once you have researched the logs then if that passes it's time to get serious.
Next would be to agree on a price based on the pre-buy inspection. The broker will know how to set this up. All money's go into an Escrow. A Title search is initiated during the pre-buy. Be ready to walk if any doors close. Don't let your emotions drive the deal. There's a lot of junk out there so it's hard to find the right one. The pre-buy should be done in your control not the sellers. Do not use the shop that the seller uses for maintenance. It may be that you have to bring a A&P in to do the pre-buy or take the airplane to another facility. Make sure the agreed procedure for the inspection and repairs is followed.
Then if the plane passes the pre-buy you sit down and agree on the inspection costs, work done and condition of the plane. When everything is a green light then the money is exchanged and contracts signed.
Don't forget insurance, the only history that the FAA will have is filed STC's (Form 337) which is good to know but should be in the logs too.
Probably have to be logged in for this info on AOPA
https://www.aopa.org/go-fly/aircraft...ng-an-aircraft
Unread 09-04-19, 01:49 PM
Thanks all.
I did see that AOPA page before, but it doesn't seem to lay out steps so much as point to forms involved.
Once the seller has been paid, and it's time to go home:
It's my understanding currently, that to take the aircraft home, you need only to have a bill of sale filled out (not submitted to any other party/agency at this point), and the "back" of the registration filled out with the buyer's name and address, and the seller's signature (also not sent or copied to any other party at this time). Simply filling out and holding onto the above two documents makes your possession and transport home of said aircraft 100% legal. Is that correct?
Unread 09-04-19, 08:03 PM
Forms for Buying and Selling Aircraft
Aircraft Registration (AC Form 8050-1)
Aircraft Bill of Sale (AC Form 8050-2)
8050-3- Current registration in aircraft, back filled out, signed and sent into FAA.
Information if registering aircraft in an LLC
Sample Aircraft Purchase/Sales Agreement
An airworthiness certificate usually is transferred with an airplane when it is sold, but the certificate alone does not fulfill the regulatory requirement. A buyer must ensure that the airworthiness certificate is, as the regulation specifies, current.
Unread 09-05-19, 04:20 PM
I have finally found an AOPA article on exactly this. It isn't dated (for shame) but appears rather current.
