Unread 10-20-16, 09:01 PM
Under/Over Voltage Sensor
My model 1968 C Skymaster has a Under/Over Voltage Sensor that is located behind the throttle quadrant. This unit is suppose to sense High Volts and Batt Discharge situations and then lights up a light above the Master Switch. Mine hasn't worked for a long time and I was trying to get it back on line. I have two other units that are "as removed" from Skymasters but can not get either of those to work either.
Has anyone had any experience with this unit? There is a board with resistors and transistors also a capacitor. I tried my board with another capacitor and nope.
See the attachments for info
Name:	Screenshot 2016-10-20 20.49.08.png
ID:	1684   Click image for larger version
Name:	Screenshot 2016-10-20 20.45.11.png
Unread 10-21-16, 01:02 AM
fsnewton's Avatar
fsnewton fsnewton is offline
I'm guessing you did an ohm check for all the resistors? Could very well be a friend resistor that opened the circuit.
Unread 10-21-16, 06:00 AM
pilotpat pilotpat is offline
pilotpat is on a distinguished road
Any chance there is no power to the circuit, like a broken power or ground wire somewhere? Would be consistent with no unit working.
Unread 10-21-16, 07:06 PM
There is power to the unit as the light does glow dim. There are pots that can be adjusted for calibration but no luck trying to use those.
I will check with Craig to see if he ohmed the resistors
Thanks guys
Unread 10-22-16, 03:02 AM
DrDave DrDave is offline
Herb:
The most common component in that schematic to fail is the capacitor (C1). These are inexpensive foil caps that tend to leak.
Unread 10-23-16, 03:48 PM
Tried a different capacitor off one of the "as removed" units on my unit and it did the same thing as my unit was doing. Any ideas where a person can get the capacitor?
