Unread 02-12-05, 06:31 AM
STEFAN CEGIELSK STEFAN CEGIELSK is offline
STEFAN CEGIELSK is an unknown quantity at this point
Question new fuel caps
can anyone tell me if fuel caps are available for my 337c.
many thanks
Unread 02-12-05, 02:06 PM
I have a web page that some have found helpful in finding parts for Skymasters. It walks you through the methodology of what kind of parts to buy (should I buy used, overhaul, PMA, surplus, new? ) and then gives you a list of suppliers who have performed well in the past. You will find there who to call. Go to www.SkymasterUS.com and click on "Purchasing Parts".
Unread 02-13-05, 10:08 AM
FRED-E's Avatar
FRED-E FRED-E is offline
Fuel Caps
Stefan
What type of FUEL CAPS does your 337C have, are the the old thermos-bottle type like the ones on my 337B, if so you need to install the NEW type cap with the ridge down the middle of the lid
I installed these on my plane a few years ago when I gave up looking for the old thermos-bottle type to replace mine. At the time the cost was about $ 400 for all four caps and lids.
Fred N358
Unread 02-13-05, 01:31 PM
Ron Moore Ron Moore is offline
Ron Moore is an unknown quantity at this point
gas caps
My 76 H has two caps, I replaced them with generic 3 inch caps from aircraft spruce. I was told they no longer make the Cessna cap,oritginal caps I found were several times more expensive than generic three inch caps.
I did have to grind the clamp slightly to get it to fit under the door.
Unread 02-19-05, 03:22 PM
The Cessna Mod Kit to replace the "thermos bottle cap" is SK337-40C. It can be ordered from any Cessna dealer. Last time I bought a kit it was more than $500. I recommend it because it adds a plate at the tank filler opening that has a raised lip to eliminate water getting into the tank, has a smaller opening to preclude getting a jet fuel nozzle in it and adds vented caps. I have a few extra parts for sale but not a complete kit.
Don Nieser
Commodore Aerospace Corp
6221 Commodore Lane
Oklahoma City OK 73162
405-722-4079 phone and FAX
405-503-4686 cell
nieser.02.337parts@juno.com
Unread 07-11-15, 04:59 PM
Don Nieser
6221 Commodore Lane
405-503-4686 cell
Ed
This is the information that Don posted back in 2005. It refers to a kit that replaces the older thermos style with the better units like I posted the links to. Not sure what the cost is to buy the kits that Don refers to but I know that my plane had them installed years ago as it had the old style like yours.
Unread 05-31-05, 04:44 PM
fuel caps
had to fit the new kit .Much better
thanks for all the information
stefan
Unread 07-10-15, 11:25 AM
Just starting a search for replacement fuel caps for my 1973 G model. Anyone have any laying around they don't need? Any suggestions of where I might get some besides Don Neiser (who I will contact) would be appreciated!
Thanks Ed
Unread 07-10-15, 04:05 PM
Fuel Cap
Part # 156003-0101
http://www.aircraftspruce.com/catalo...ssnaparts8.php
http://www.controller.com/list/Parts...m=C156003-0101
Unread 07-10-15, 10:10 PM
Thanks Herb,
These are different then mine. I like these better but the 337G has the type where they drop in and then push the lever down which squishes the top and bottom together to squeeze the rubber to fit tight in the fuel port. These might be referred to as "thermos" type caps. Anyway, I 'll look up the part number in my parts manual and look harder. I just threw this out there to see if anyone had any around they did not need.
Thanks again,
Ed
