Unread 02-16-06, 07:59 PM
GMPoland GMPoland is offline
GMPoland is on a distinguished road
Fuel Venting from left reserve tank
Seems my normally reliable skymaster has developed a leak that has me puzzled. After the last top up the FBO called to inform me that there was fuel leaking from my acft. closer inspection revealed that the left inboard was overfull and leaking from the vent. left main that had been topped of was down slightly. Draining from the reserve stoped the problem only slightly. Next day same thing. I drained the reserve and aprox 15 Gal from the mains and the leak has stoped. this is concerning me greatly as the fuel tank selectors were in the off position during all this. I have the parts and service manuals and I can only think that I have one or both fuel selector valves that have gone bad. My acft is a 337A SN 0127. I drained this fuel from the front and rear fuel gascolators. I dont think this this should be possible with the fuel valves in the off position. My local shop is great but has little experience with the Acft type. Any comment on this?
GM Poland
Unread 02-16-06, 08:06 PM
I'm not sure I fully understand what you wrote, but I think the leak may well be due to a small crack in the upper part of one of the tanks. This is a common problem, and draining some fuel solves it because the fluid level is then below the crack.
Unread 02-16-06, 09:02 PM
Fuel vent
Sorry for the lengthy description. Basically,with the fuel tank selector valves in the off position can fuel be drained in that amount from the gascolators? IF not then where would this fuel come from? The parts and sevice diagrams for this year are not too clear as far as the selector valves are concerned. My thoughts were that the fuel was draining through the bad selector valve into the lines and reserve tank thus overflowing until it either equalized or was empty. The comment about the cracked tank has me more concerned than the possibilty of bad valves. If it is a cracked tank what would be a viable repair or is replacent the only option. thanks
Unread 02-16-06, 11:28 PM
I had a '69 337D with separate (inboard) aux tanks and I now have a '73 337G with the long-range tanks, but only one filler cap per wing. I don't know what the gascolators are. If it's the sump at the bottom of the boom, from where you drain fuel to check for water, then I believe that these sumps have fuel even if the tank selector valves are closed; in other words, the valves are downstream from the sumps.
Because these sumps are the lowest part of the wing, even if a leak is on the upper part of a tank, the fuel may appear to come from the sump area.
I believe that tank cracks can be repaired, but I'm not certain; my A&P is out of the country, so I can't ask him, but maybe someone on this board will tell us.
Unread 02-17-06, 02:43 AM
scade scade is offline
scade is an unknown quantity at this point
I had a similar situation with my 1966 337A. After all tanks were topped-off, aircraft was parked for a day. Returned to find a significant amount of fuel was missing from the main tank and the aux tank was over flowing through the vent.
I ran the airplane a few minutes on the ground from the aux tank and exercised the fuel valve. The leaking stopped and so far has not returned. I don’t know for sure but think the fuel valve must have been slightly out of position possibly allowing fuel from the main tank (higher elevation) through the valve into the aux tank causing it to overflow.
Steve
Unread 02-18-06, 01:28 PM
general's Avatar
general general is offline
Exclamation venting allot of fuel
I have seen this allot with my pre 1973 337/336's. After the tanks are topped-off, aircraft was parked for a day or so. I would returned to find a significant amount of fuel was missing!!!! And then and find flowing through the vent, and not just by the change of temp.
I think the fuel valves might be out of position possibly or some thing is leaking most of the time I have found is that one wing is a few in's lower on the parking ramp.
I do know one thing check you fuel tank each time you fly I have tip them off the day before and found 25 gals or more less fuel "not good if you are flying over water like I do!!! DO YOUR PREFLIGHT LOOK into the Tanks!!!!!!
The General
General Sky
Unread 03-13-06, 09:39 PM
Talking Fuel Leak
After an extensive look at the fuel system in my aircraft the problem was found. seems that during previous maintenace the plackard on the overhead fuel panel had been installed reversed. Thats right. BACKWARDS. This was an easy fix, However, realizing the potential for disaster during the previous flights over the past 15 months has made me very cautious about checking up after the mechanics have worked on my aircraft. And for all the replies, Thank You for your advice. the information was very helpfull.
Unread 03-14-06, 07:18 PM
That could have been disasterous. I am glad nothing happened because of this mistake.
I am surprised that this could happen. I have a '68 C model and have taken off the placard before for cosmetic repair issues. I did not think that this could be done. As I am looking in the service manual right now I can see by the diagram that it actually looks like it could be reversed. But then you would be reading the words upside down or if it was flipped the words would be backwords.
The D model changed the shape so that it only fits one way.
Unread 03-18-10, 12:33 AM
My aircraft finished it's annual about 5 weeks ago, but I performed some fixes on it myself. Today I finished the fixes and filled the main tanks up. As soon as the line person filled up the tanks it started leaking fuel fast. Fuel came out of this small hole in the wing near the outside of the both booms (not the drain valves) and started flowing inside the booms leaking out of the seams and flowed all the way to the passenger windows on both sides and started flowing down there. One side finally stopped and after waiting 15 minutes, the other side slowed down considerable. I plan to go back tomorrow morning to see if it has stopped completely. My question is, when my aircraft overflows because fuel is topped off (1966 C337A), is it suppose to just flow out the vent or have other experienced it flowing all over the wing, boom, and fuselage. I'm guessing the mechanic didn't put something back together right, but I wanted to check with the forum first.
Karl
Unread 03-18-10, 06:24 AM
Before you want to blame the mechanic, was this a routine annual inspection? Was there any fuel tank maintenance performed, ie, fuel quantity probes/liquidometers, stress plates over the tanks removed? Its not normal for the tanks to leak if gaskets and hoses have not been disturbed.
Please provide some insight and additional information.
Unread 03-18-10, 08:36 AM
As Dave suggested, more information is needed to determine what may have caused this to happen. NO, it is not normal for the fuel to migrate to the booms and inside the wings as you have described. The main tank(s) on each wing are two separate fuel cells connected by three couplers, two lower and one upper. The only other port on the fuel cell is the line that delivers fuel to the fuel sump in the boom where the quick drain is. Without knowing what maintenance was performed it is difficult to determine what may have caused this problem.
Need more info..........
Unread 03-18-10, 09:53 AM
Roger's Avatar
Roger Roger is offline
My 80-H was sitting for a month with minimal fuel in it last year and a few minutes after it was topped off all of the fuel started running out the two holes where the fuel supms stick through the bottom of the wing. If turned out to be the cork gaskets on top of the inboard wings(s) that are the tank inspection plates where the inboard fuel guage pickups are located. We sent for new cork gaskets, replaced, and the have both beeb perfeect ever since. Apparently as they age, if they are left to dry out (minimal fuel for an extended period of time) they start to leak.
And yes you can weld the fuel tanks. There is a guy in I believe Deland, FL that is an expert, who also does symaster refurbishemnt and conversions. If anybody needs the name and nuymber I can get it from my IA.
And lastly, this again points out why is is vital to have your fuel guages working, vs just a good fuel computer. Anything that leaks out is not being picked up by the computer.
