Unread 09-11-11, 09:16 PM
Gord Tessier's Avatar
Latest revision to maintenance manual
Has anyone seen the latest revision to the mm ?
D2500 2TR9 dated oct 2010
If so what are the changes?
Gord
Gord
C-FTES
Unread 09-12-11, 04:04 PM
Just talked to Cessna. It's a 300 page inspection document revision.
I ordered it as I have the paper manual.
Once I get it I will post comments.
Gord
C-FTES
Unread 09-13-11, 10:06 AM
Gord
Cessna is referring to the SID's document?
Unread 09-13-11, 10:46 AM
Hi Herb, Are you asking if it was SID related or have you seen the revsion and know its sid related? Judging by the size (over 300 pages as I was told) I would assume its a major rewrite. the guy who took the order could only say it had to do with inspections. let me know.
Gord
C-FTES
Unread 09-14-11, 10:10 AM
I was asking if the document you referred to is the published SID's that we have been wondering about since the last meeting with Cessna almost 2 years ago. I also ordered a copy of the -13 revision which applies to the 65-73 models. I ordered one through Yingling for $8. I will post the results once it arrives.
Cessna indicated that they would revise the maintenance manual (MM) to include the new inspections (SID's) as the method of print. The fear was if someone hired a big shop that had all the new documents they might feel they are obligated to perform all inspections that the manufacturer has included in the MM.
From what I see the revision was published Oct 2010.
Unread 09-14-11, 11:15 AM
Hi Herb, thanks for the clarification.
Gord
C-FTES
