Unread 02-22-10, 04:29 PM
bking bking is offline
bking is on a distinguished road
Gear Horn and Volts High Light
I have experienced two problems which have baffled my mechanics and hope someone has advice or suggestions as to the possible causes and solutions.
1. While taxing on several occasions the gear horn has sounded with the gear down and locked. Someone told me to cycle the manual gear extension pump a couple of times and that seems to do the trick.
2. Approximately 30% to 40 % of the time when in flight and the gear is extended the Volts High light illuminates and the rear alternator drops off line. The problem goes away when the reset procedure in the POH. What would cause this to occur only when the gear is cycles down?
Thank you in advance for any help/comments,
BKING
Unread 02-22-10, 06:00 PM
Could you please provide the model of your aircraft.
Unread 02-22-10, 08:51 PM
Bking, is it the 74 337G in your public profile?
Unread 02-22-10, 11:49 PM
Gear horn I cannot explain however see my posting on "over-voltage". This might help you.
Good luck, Ed
Unread 02-23-10, 02:14 AM
This almost seems like a short in the wire. I'd look around where the mains rotate and where the nose gear swivels.
Unread 02-23-10, 06:54 AM
Yes and thank you for the quick responce.
Bking
Unread 02-23-10, 06:56 AM
My Skymaster is a 1974 G model with the gear door mod.
Thank you for the quick responce,
Bking
Unread 02-23-10, 06:57 AM
Will do.
Thank you,
Bking
Unread 03-20-10, 08:57 PM
Gear Horn
I am having a gear horn problem too. When I turn on the master switch, if the throttles are in the fully retarded position the gear horn will sound for a few seconds and then function normally. After I clean out my pants, I will engage the starter (either one) and the horn will sound again briefly... with each start. The green Gear Down light is on steadily during this process.
I did some voltage checks on the Dual horn assembly. There are 5 screw terminals on the module. I noted the following results with the Master switch on:
Green Gear Down light on.
Gear Horn sounding
With a voltmeter - Negative lead to airframe -
Measurements on screw terminals
Ground terminal - 0 volts (V)
Gear Terminal - 24 V
Power Terminal (center) - 24 V
Stall Horn Terminal - 24 V (stall horn was silent)
Throttle terminal (Throttles fully retarded) 0 V
Then, a little surprise. My airplane has a module part number 1213242-1 installed. It is clearly labeled as a 12 volt unit. The parts list calls for a 1213242-2 unit. When I do research on the Internet, that part number is listed as a 24 volt unit. Interestingly enough, the unit in my airplane has functioned perfectly for the 18 years I have owned the airplane.
When I read the operational description in the aircraft maintenance manual, I find that when the test button is pressed, the gear horn should sound while the switch is about half-way engaged and the light should be on when fully pressed. My inpression is that when voltage is applied to the Gear terminal of the gear warning unit, the horn should be silent. If this is the case, the indications are that my Gear horn module has failed - not the wiring or switching for the gear warning circuit.
Can anyone confirm if my logic is correct? I really hate to spend $1800 for a new unit that I don't need.
Does anyone have a diagram of the dual horn module? It may be able to determine the validity of my troubleshooting.
