Unread 06-05-02, 09:32 AM
Unusable fuel in a 337G
Does anyone know how much unusable fuel in each long-range tank of a 337G? It's non-turbo, non-pressurized.
Going through the manual I notice on the Instrument Markings section that my 337G has 21.0 lbs -- 7 gal -- of unusable fuel on EACH long range tank. So, out of 125 gal, 14 are unusable? Sounds like a typo to me that should have read 2.1 lbs or 2.1 gal (it's only 2.5 lbs per tank for each standard tank). I mean, LR tanks take you from 93 gal to 125 gal, or 32 more gal, so it seems ridiculous that 14 of those 32 are unusable. Maybe Cessna issued an errata sheet and it's in your manual, or do you have any first-hand experience?
Thanks for the help.
Unread 06-05-02, 11:14 AM
21 pounds of fuel is only 3.5 gallons, so you'd have 7 unusable for both tanks together, not 7 each. That seems more like what I'd expect.
Mitch
67-21309
(O2-A)
Unread 06-05-02, 07:08 PM
Excuse my bad math, Mitch, it's indeed 7 gal total, or 3.5 gal per side, which isn't that bad. But how come the std tank only has 2.5 lbs per tank unusable instead of 21 lbs? Unless that's where the mistake is, that it's 2.5 gal and they forgot to change it to 15 lbs.
Unread 06-11-02, 03:22 PM
Burt Benson Burt Benson is offline
Burt Benson is an unknown quantity at this point
I have the 150 gallon (75/side) long range tanks and only two gallons (one/side) are unusable.
Burt
