Unread 03-26-25, 08:48 AM
Bhump Bhump is offline
Bhump is on a distinguished road
Pressurization outflow valves
Trying to find a leak in a 1973 pressurized skymaster for a friend. I am running pressure air thru front engine access with electric blower. In theory with master power off the outflow valves should be normally closed. However I have full air blowing out the outflow valve and backup outflow valve. Does this make sense?
Unread 04-02-25, 06:20 PM
It's standard Cessna so most Cessna shops that work on P models should be able to help you with that. Not sure if there's a process listed in the service manual, do you have the SM? Can send if you need one
Unread 04-03-25, 08:08 PM
Ed A Ed A is offline
Ed A is on a distinguished road
CPA Tech Note No. 337T-01
According to Tom Carr the outflow valves have to be blocked off.
See the attachment below.
Unread 04-05-25, 01:54 PM
Nice find, Ed!
