Unread 03-13-23, 06:28 PM
Fuel tank transducer leak, bummer
Filled plane up the other day for a trip the next day to Florida. Arrival in the hangar, fuel smell, fuel at RH wing root going down fuselage. Removed tank covers with screw buster, only had to drill a couple. Both transducer plates leaking, good thing I had 100 gaskets made out of grade A viton. Should have done it last year when I did the LH wing. Modified the holes in the plates with a 60 degree counter sink, installed small viton oring under bolt washer and reinstalled. Wish I would have done it last year.
Dan
Unread 03-14-23, 09:14 PM
Pics or it didn't happen
Unread 03-15-23, 09:35 AM
ljmolina's Avatar
ljmolina ljmolina is offline
second that..
Unread 03-15-23, 10:57 AM
Burt Burt is offline
Same thing happened to me when I filled the Aux tanks for a trip from Sacramento to Tucson. Discovered that if I only put 12 gallons in the right aux instead of filling it then it did not leak. Still have not gotten around to pulling the tank cover.
Unread 03-15-23, 02:11 PM
Here are a couple pics
Dan
File Type: jpeg 22FBE37F-6B17-4F42-8CB0-5B25741E44E2.jpeg (283.5 KB, 2112 views)
File Type: jpeg 8A4A099D-9D9D-47FE-98FC-B22F696A8E77.jpeg (406.3 KB, 1851 views)
Unread 03-15-23, 10:36 PM
Like the o ring idea on the bolts. Just finished CiES probes and used a dab of fuel resistant sealer on the bolts for the access plates. CiES probe plates come with viton gaskets like you had made.
