Unread 02-19-03, 01:11 PM
Keven
Washington DC Area
I'm planning a 5 day trip to DC in early April, and will be staying in the downtown part of DC. Any suggestions on the best airport to use? I saw that Executive and the airport right next to it were both about 8 miles SE. Any reports or comments on these airports? Transportation to and from? Fuel prices? Suggestions for others?
Keven
Paxil lawsuit settlements
Unread 02-19-03, 06:41 PM
Keven:
I lived in the DC area for 20 years. Although I wasn't a pilot then, I know the area well and have often planned to fly up there in my Skymaster.
Let me offer two suggestions.
Manassas Regional ( http://www.airnav.com/airport/KHEF ) is on the SW outskirts of the DC Metropolitan Area. Although it's inside the new ADIZ which surrounds DC, which requires that you be in contact with ATC and have a discrete squawk code (either IFR or VFR Flight Following), it's in a fairly uncongested area and easy to get to (especially coming in from the South like you will), although you need a rental car to get downtown because a taxi would be expensive.
Another choice is Potomac Airfield ( http://potomac-airfield.com/ ) belonging to David Wartofsky (301 248-5720) who owns a Skymaster and used to be a frequent (although ultra-conservative) contributor to Peter's website. This is probably the airport closest to downtown DC, and therefore inside the ADIZ, which requires that you be in contact with ATC and have a discrete squawk code (either IFR or VFR Flight Following). But 100LL is $1.79 for airfield-based aircraft and maybe David will extend the same courtesy to you.
In terms of advertised fuel prices, I use www.airnav.com and it shows that College Park (KCGS) is the cheapest around at $2.00, but the downside is that it's on the North side of all the congestion, so it's not as easy to get to.
Unread 02-20-03, 08:43 AM
re washington
Potomac field is verboten for alien aircraft (not based at potomac).
check other airports.
there is an ADIZ over washington at the moment due to raised terrorist threat. .
Suggest further afield and rent a car........
