Unread 01-02-18, 07:24 PM
Gyro Overhaul
I am going to have my AI and the DG overhauled during annual this month. Anyone have any good references to shops they have used?
Unread 01-02-18, 07:52 PM
kilr4d's Avatar
kilr4d kilr4d is offline
Herb,
I haven't used them myself but Aircraft Quality Instruments are highly recommended on a couple of the larger GA forums. http://flyaqi.com/
-John
_________
John K
1977 337G
CNC3
Unread 01-02-18, 08:39 PM
John
I have used AQI once for a customer plane and was happy with the results
Unread 01-03-18, 12:21 AM
Consider going glass with Garmin's new G5 attitude indicator. Might be same price as an overhaul on the round gauges.
Unread 01-03-18, 11:02 AM
kilr4d's Avatar
He might need one or both of those gyros to drive the autopilot....
_________
John K
1977 337G
CNC3
Unread 01-03-18, 11:46 AM
Flyer770 Flyer770 is offline
Flyer770 is on a distinguished road
And depending on the autopilot, the G5 may be able to interface with it. Stec and Garmin autopilots will work. Of course, if it’s a Cessna autopilot like mine, he’d be out of luck.
Unread 01-04-18, 01:44 AM
JamesC JamesC is offline
The DG in my old Skymaster needed an O/H and it wasn't that much more $$$ to put in an Aspen pro so that's what we did. Their EA100 adaptor emulated the DG ie it let the Aspen AHRS talk to the Cessna autopilot. Landmark Aviation avionics did a good job.
Unread 01-06-18, 01:23 PM
The DG in my 1968 drives the autopilot and that will be a problem with the new stuff out there. The Aspen would work but the highest price I have gotten to O/H is about $1500.00 If I could put an Aspen in for that it would be there. $1500 won't buy you the schedule at the radio shop. Last I checked the Aspen pushes $20k installed
Unread 01-07-18, 11:50 PM
DrDave DrDave is offline
Herb:
I guessing that your autopilot DG is a 52D54(?). The high overhaul price is for the electrical part of the DG. The vacuum driven mechanism should be around $350. If the heading pre-select and course bug are right on there is not much for them to do with that part of the DG.
Unread 01-08-18, 05:09 PM
kilr4d's Avatar
Tried either of these?
http://rudyaircraftinstruments.com/Overhaul_Prices.html
http://www.centuryinstruments.net/Web_Specials.htm
_________
John K
1977 337G
CNC3
Unread 01-08-18, 10:36 PM
Originally Posted by DrDave View Post
Herb:
The DG is an A.I.M. model 200-3 There is no bug on the DG, the heading bug is built into the auto pilot, Cessna straight 400
I think the Cessna model number is G520 or (G502A)
Unread 01-08-18, 10:41 PM
I've heard of Century. their price list on their website lists the G502A DG
Have you used any of these repair stations?
Unread 01-11-18, 12:19 PM
kilr4d's Avatar
I have not, both come recommended on BeechTalk and Cessna Pilots Society.
I'm also taking notes as I'd like to send my DG out for iran.
_________
John K
1977 337G
CNC3
