Unread 10-06-09, 12:33 AM
kgovett kgovett is offline
kgovett is on a distinguished road
Check valve help
I am having problems getting the corrrect part number for the front engine turbo oil return hose check valve.
My Cessna IPC notes it as being 3142-00 and have been told that the P/N goes to P/N S2360-1. Can someone please help.
The valve is a #8 male to male AN fitting on each end.
The IPC shows the same P/N on the rear turbo but that is wrong.
Thank You, Kevin
214-226-1504
Unread 10-06-09, 12:33 PM
K337A's Avatar
K337A K337A is offline
The #S2360-1 is the latest part #. This is a common part to Turboed TCM's I believe . Don most likely will have it. He's in OKC. Try him first if he dosn't have it I would venture to say he would point you the right way. Permier has it for $124. Your Dad's plane looks nice. Where is it based around Dallas?
Don Niser- http://02337parts.com/
Unread 10-06-09, 05:20 PM
check valve help
Thanks, It is in Okc and I am going to move it to Fort Worth TX.
Unread 10-07-09, 01:15 AM
Check valve help
Can you please send me the phone number to Premier?
I am new to the Skymaster. I have spent the majority of my time as an A&P working on turbo prop and jets.
Thanks, Kevin
214-226-1504
Unread 10-07-09, 03:48 PM
K337A's Avatar
Kevin-
Here is the website. They operate out of Arizona. I would try Preferred parts also. The parts for your aircraft are available for the most part. Finding the best price is the hard part for many items.
Premier - http://www.iwantcessnaparts.com/
- http://www.cessnaparts.com/
Preferred/New and Salvage - http://www.preferredairparts.com/
Mr. Martin has a extensive list and outline which is very well constructed concerning the purchase of C337 parts.
Here- http://www.skymasterus.com/
Good luck with your aircraft.
