Unread 03-26-09, 11:15 PM
nick nick is offline
nick is an unknown quantity at this point
cargo pod pix
I need actual close up pictures of the cargo pod parameter mounted on the belly. close up pictures of the cargo pod
nose (by nose gear door), rear, above cargo pod door and under the main door. I am in the process of the installation of the pod and want to make sure I have it situated correctly. Also a picture of the front cowl flap extended. Please email pictures to:
nicknazari@gmail.com
Nick(909)772-6563
Unread 06-09-09, 03:58 PM
Nick did you ever get that pod mounted? If so can you share pics with me? I just bought a pod, used of course, and would like the gouge on how to mount it in the right spot.
Rob
Unread 06-10-09, 11:48 AM
cargo pod
need to get installation instruction from cessna TECH SUPPORT. cost is $104. I can send you a copy for $50. It is only four pages.
Unread 06-11-09, 01:13 AM
Ok, sounds like a plan. Where to send the check?
Unread 06-11-09, 01:35 PM
cargo pod inst.
Rob,
please send an email to me with your information and I will forward you mine.
thanks nick
Unread 06-29-09, 12:09 AM
Nick, did you mount antennas on the pod, or just left them on the belly? The instructions don't really address the antenna issue.
Unread 06-29-09, 11:55 PM
cargo pod
I first took the antenna off, and fabricated a replacement plate. Later, I decided to install the antenna back in the pod, but I think it should be left out because it can easily be damaged by any luggage in the pod. I was selling the airplane and I did not want to remove the ADF. Otherwise, I would have pulled the whole ADF unit out.
