Unread 06-02-03, 08:36 PM
Frank Benvin's Avatar
Flap Cable Failure
Transport Canada just released Service Difficulty Alert AL-2003-05 May 16/03 Cessna 336&337 Flap Cable Failure P/N 1460100-7 & 1460100-8 They recommend owners & operators remove and inspect flap cables before or on the next 100Hr inspection.
Frank
Unread 06-04-03, 07:24 PM
what basis did they come to this conclusion? hours, type of flying, different models , age, location or what? how many incidence have taken place or inspection that found problems with the cables
Unread 06-04-03, 09:08 PM
In short: The report is # TP7244 I looked it up
on Transport Canadas Web site. They do not post it.You get a copy if you are an owner. It was reported by the Service Difficulty Reporting Program. They mention that Cessna's Pilots Assoc. has put out an artical on it. They also mention FAA AC43.13-1B which says cable lubrication can delay the wearing condition.
I do not know how they came up with this conclusion.
I can fax you a copy if you wish
Frank
Unread 12-15-08, 01:37 PM
rrice rrice is offline
I can vouch for the validity of this inspection.
Robert Rice
Great Commission Air
www.GreatCommissionAir.org
Unread 12-15-08, 05:35 PM
Paul462 Paul462 is offline
Search this message board for "flap cable". The 6th hit is the ACS Flap Cable thread. It discusses the flap cable failure problem, and the Australian failure on short final that could have been serious.
Paul
T337C
Unread 12-15-08, 05:59 PM
Tony
Transport Canada brought this to our attention about 3 years ago. I checked the cables on the skymaster I was looking after and both cables were frayed. One was over 50% frayed. The only way you can tell is to remove them from the bellcrank. Airframe time on this skymaster was about 5000 hrs.
