Unread 11-30-05, 08:24 PM
Guy Paris's Avatar
Cool Front cowl flaps motor... C610501-0101
Hey guy's,
Anyone have first hand experince with Owen Bell's overhauled front cowl flap motor? ($1600) exchanged...
Anyone have any experience with his new (PMA) cowl flap motor? ($2100) exchanged...
How about Don Nieser's overhaul of cowl flap motors.
Guy... (old72driver@msn.com)
Unread 11-30-05, 09:54 PM
Jim Rainer's Avatar
Go to the "Parts for Sale" forum and type "cowl flap motor" in the search window and you'll see several suggestions for the motors including one from me.
Jim Rainer
Unread 12-02-05, 07:29 AM
Several years ago I purchased a used cowl flap motor from Mr. Bell. It was very noisy when I ran it on the bench. When informed of this he exchanged it for another one which is still in service.
Ed Coffman
Nevada dispensaries
Unread 12-02-05, 02:01 PM
I have one of Mr. Bell's rear motors in, and it runs flawlessly. Far better than the one it replaced (which did not function at all)
Unread 12-03-05, 08:10 AM
cowl motors
Guy
1) Has your mechanic checked the resistance of the motor?
2) Suggest you soak it in CRC contact cleaner and try applying 24v momentarily to see if it may work.
3) if you are technical then check brushes.
oil from front engine can cause problems and create enough dirt etc. to stop it's operation.
keep linkages well lubricated and always adjust limit switches with full voltage on system to avoid overuns when set by low voltage (suggest adding battery charger to aircraft while adjusting.
I find spraying CRC cleaner after every oil change makes a big difference in performance and reliability.
if all above fails then "open the wallet"
for what it's worth..........
Unread 12-04-05, 03:50 PM
Frank Benvin's Avatar
Make sure you check your fuses in the engine compartment for your cowl flap motors. Someone put fuses that were over three
times the rated fuse size in ours. Check your manual for sizes.
Unread 12-05-05, 04:46 AM
sunnysky sunnysky is offline
We had problems with our front cowl flap motor. Intermittent operation. It wouldn't start if it stopped in certain positions. The problem was worn brushes and some broken wires in the windings. As new brushes are not available, a friend managed to adapt some simular ones from another motor by careful filing. With the aid of a microscope, he was able to re solder the "ultra thin winidings" that had also broken. This was over 2 years ago and the motor is still working fine.
These are the usual problems with these motors and if you know somebody with some basic skills, they are repairable.
Sunnysky.
Unread 12-05-05, 10:16 AM
Guy Paris's Avatar
Cool front cowl flap motor....
I should have prefaced the issue that it is still running but not
sounding normal, a strained noise... It's out of the plane and at
a small electric motor repair shop. They have not looked at it thus
far. Thanks Jerry, Jim, Ed, Larry, Bob, Frank and Sunnysky... guy
Unread 12-09-05, 10:58 AM
Guy Paris's Avatar
Cool Cowl flap motor update....
Cowl flap motor appears to be running fine! (3) new bearings, (1) new brush (lead broke), cleaned and lubed. Reinstalled in my hangar... burrr, it sure was cold... guy
Unread 12-09-05, 11:43 AM
Jim Rainer's Avatar
Thumbs up
Guy, that's good news! If you don't mind, tell us what it cost you to get the motor repaired, please.
