Unread 11-23-22, 02:50 PM
Gas Heater fuel pump
Just popped the end cap off of my cabin heater fuel pump the other day due to seeping of fuel, thought it just needed a new gasket. Wow, after removing the cap it obviously had not been off in a long time and I can’t believe the heater worked with all the rust and junk in there. There is a filter in there that is cleanable with the original Bendix pumps. The newer ones have a red plastic tumbler for the screen.
Ended up going to Safe Skies and got a used Bendix pump that was clean on the inside. If you acquire a used replacement, be sure to have them take the end cap off to make sure it is clean on the inside.
Dan
N67S
Unread 11-24-22, 12:37 AM
That’s good advice, thank you Dan.
N337K-FT337GP
KLOU
