Unread 01-17-22, 08:48 PM
OhioSkymaster OhioSkymaster is offline
OhioSkymaster is on a distinguished road
Nosegear Warning Plate
I have seen a red warning label on the nosegear of a few other Skymasters but mine doesn't have one and there is no information on it in the manuals that I can find. Can anyone tell me what it says? I should have written it down when I saw it, but did not.
Unread 01-17-22, 09:47 PM
You can find a list of the required placards in the A6CE type certificate.
You can have new stickers made by a local print shop.
Attached is a photo of the placard in my ‘77 G model gear (one on underside of each nose gear door and 1 on inside of each main gear spring door).
File Type: jpeg 7519B9CE-BCF5-4D56-8A0A-9C4CA414D828.jpeg (394.0 KB, 2220 views)
Unread 01-18-22, 09:45 AM
MD83driver's Avatar
Would this be the one your are thinking of. Off of my P337H. Before restoring it.
They can't stop the signal.
Unread 01-18-22, 08:58 PM
OhioSkymaster, if you're looking for the placard about the hydraulic pump circuit breaker, I had some made for my plane, along with a slew of other placards also.
The guy that made them would still have the template and can make more of them if that's what you're after. He's available at dean@pipts.com.
MD83Driver, I don't recall seeing that placard. I remember reading about it though. Where does it go?
Rick
N337K-FT337GP
KLOU
Unread 01-18-22, 10:04 PM
MD83driver's Avatar
Rick, The placard is shown in fig.2 Item 37. It is not shown in the parts catalog of the nose strut. Here are pictures of the installed placard as it was on my plane. These are the only pictures I have. Ray
Unread 01-18-22, 10:23 PM
Thanks Ray. Figure 2 is where I must have seen the placard.
I'll have to check whether it's there tomorrow. I'm thinking it's not...
Rick
N337K-FT337GP
KLOU
Unread 01-19-22, 12:12 PM
It's there! I'd never noticed it. Something else to restore.
Thanks again, Ray
N337K-FT337GP
KLOU
