Unread 12-30-20, 09:49 AM
Fuel Tank Gaskets Available
Fuel tank gaskets, under the fuel probe plate, available made from Viton Grade A material.
The originals made out of a composite cork compound do not hold their shape etc. Cessna's price on these gaskets is right at 300.00 each today. Depending on your aircraft your tanks use a total of 4 or 6 of these gaskets.
On my aircraft I have also cut a 30 degree (60 degree conical) countersink in the fuel probe plate and have installed a vition oring under the small washers to seal the bolts from leaking.
The gasket that I have available is p/n SE 1516118-1, grade A Viton, owner produced, 49.00 dollars each.
Dan
N67S
picture to follow.
Unread 12-30-20, 03:22 PM
Glad to see this! Please do post pics!
Unread 12-30-20, 09:01 PM
hayesjaj hayesjaj is offline
I am right in the middle of going through my tanks and there is no way i’m paying $1200 for bad gaskets when I can replace with a whole kit from cies for 2400, which includes gaskets. May be interested in this though.
Unread 01-03-21, 02:19 PM
1/16 inch grade A Viton
Dan
Schultzav@woh.rr.com
File Type: jpeg 5DD59F61-3E04-4090-9094-494499627085.jpeg (325.5 KB, 3498 views)
