Unread 03-16-20, 04:54 PM
TomM's Avatar
TomM TomM is offline
What is this?
I need to tap the knowledge base here......had the chance to see the plane in person for the first time this weekend. I LOVE it!! Should have bought one of these years ago......
Ok, on to the business at hand. I have a previous Skymaster owner who is a CFI training me in the plane. This week we went over the preflight stuff and systems check/familiarity work. While going over the plane we came across this "thing" sticking out of the wing. His 1967 did not have this, and he was not sure what it was. We were thinking something to do with ice detection, but not sure. If you move it with the master switch on, I can not see or hear any device, light or buzzer this thing might control.
Please check out the picture and let me know what this thing is please. Thanks a ton!!
Unread 03-16-20, 05:27 PM
GAdams GAdams is offline
Thing a majig
It triggers the hour meter.
Unread 03-16-20, 08:44 PM
kbecker kbecker is offline
GAdams is correct. I have one of these on my 337
Unread 03-17-20, 08:49 AM
TomM's Avatar
Thanks much!
Make you think though...........if the plane was used exclusively for 1 hour hops for 1000 hours the Hobbs would say 1000........but the engines would actually have 1500 or so hours run time.......
You guys are the best, thanks!
Unread 03-17-20, 06:56 PM
MD83driver's Avatar
Here is an article from AOPA regarding flight time:
https://www.aopa.org/training-and-sa...intenance-tips
It really depends if your paying for your flight time or the one charging for the flight time.
Unread 03-18-20, 11:29 AM
air time versus flight time
Tom,
MD83Driver posted a great link. The airspeed switch on your '67 is pure genius, as it is meant to actuate at an airspeed right around take off, giving you the most accurate tach time to correctly log all your air time for airframe and engines. However, it looks like yours might be modified a little and may actuate in a strong breeze, if not cause some drag! I have attached a picture of what one looks like - the actuator paddle should trail, and when it actuates, it rests up against that little button on the lower wing skin.
