Unread 06-16-17, 12:40 PM
Gord Tessier's Avatar
Looking for a Pitot heater
Still looking. Has anyone else had any success?
Hi everyone, I am looking for a Pitot heater element OR THE ENTIRE ASSEMBLY.
Part number 6653465-003
OR
1500118-4 PITOT HEAD ASSEMBLY
It is for my 1973 337G 33701518.
It is for the internal one that is in the strut
Does anyone have one they coud sell to me?
Gord
Gord
C-FTES
Unread 06-25-17, 02:23 PM
kilr4d's Avatar
kilr4d kilr4d is offline
Hi Gord,
Not sure if you've looked, but we found one wire was off mine when we pulled the upper wing root fairing for the annual. New connector; plugged it and works like a charm.
-John
_________
John K
1977 337G
CNC3
Unread 01-29-18, 08:09 PM
LostKiwi's Avatar
LostKiwi LostKiwi is offline
Help!!
I am in need of the same thing, same P/N.
Turns out my heating element(s?) are missing, and the wire has been capped/stowed.
I assume I also need the little thermostat deal-ie-oh on the bottom?
(Refer old thread for extra pics)
http://www.337skymaster.com/messages...read.php?t=617
Leighton.
Unread 08-01-20, 12:17 AM
Heated Pitot Assy
Did anyone ever locate a source for these?
Unread 08-02-20, 09:09 PM
https://cessnadirect.com/1500118-4
Unread 09-17-20, 11:29 AM
So Cessna wants $1324 for a heating element? You may want to consider going the "owner produced part" route. The laws of electricity aren't any different just because its an aircraft part. There is a wire, or coil, that has a specified length and resistance, to produce a specified amount of heat at 28 volts dc input. These values may be obtained, and copied by the owner to produce his own replacement part.
Here's a good discussion on making your aircraft parts (or having them made for you, which is also legal): https://aviation.stackexchange.com/q...aa-regulations
Reach out to this company about building one for you custom: https://intekcorp.com/custom-heating-elements/
Finally, have you called all the airplane Junkyards? Off the top of my head: 1. Air Salvage of Dallas (ASOD) 2. Texas Air Salvage 3. White Industries Air Salvage 4. Dodson Air Salvage - There are many more smaller ones too.
#2 Texas Air Salvage has a 337 on their website currently being parted out: https://www.texasairsalvage.com/Airc...php?editid1=34
Let us know how you solve the issue!
Unread 09-17-20, 11:54 AM
Photo of heated pitot
http://www.337skymaster.com/messages...1&d=1048456518
Here is a pic from the other thread. It appears to be made of orange cowl seal siliconed around the pitot, with holes drilled for the pitot inputs and two screws. Nothing too high-tech, but there is a thermostat in the circuit as well that will have to be located if you don't have it. The original is out of production, but I'm certain a replacement is easily available as long as the on/off temp of the original part is known.
