Unread 10-25-10, 06:13 AM
ConwayB's Avatar
ConwayB ConwayB is offline
What is the Take Off Weight of the O2?
Hello all,
I have purchased an O-2A and am getting it registered in Australia. Now, here's the problem...
When the new weight and balance was done, the maximum take off weight issued by the WB inspector is 4190 lbs!
The O-2A, according to the USAF O-2 manual, had a maximum take off weight of 4850lbs and a maximum landing weight of 4400 lbs. (The extra weight was in weapons which were jettisonable in an emergency).
The O-2A is equivalent to the 337B and later... and the civilian 337B flight manual (which I have to use as the official flight manual) says the following:
" Gross weight 4000 lbs and 4400 lbs" (but with no explanation of the two numbers) as shown in Performance specifications
"The cargo loading envelope allows loading up to 4400lbs."
So can someone please tell me where I can find the definitive answer on this issue so I can ensure my WB is correct? Is there an official Cessna document available?
Thanks in advance.
Conway
Unread 10-25-10, 10:13 AM
Frank Benvin's Avatar
Gross weight
337A - 4200
337B - 4300
337C- 4400
337E - 4440
337F - 4630 take off 4400 landing
Frank
Unread 10-25-10, 11:44 AM
337D take off 4500 landing 4400
Unread 10-25-10, 05:17 PM
http://www.risingup.com/planespecs/i...plane192.shtml
The POH gives two scenarios for performance. The second column is for performance at a "less than gross weight" configuration, ie: 4000 pounds. The first column is at "gross weight" configuration, ie:4400 pounds. My POH for the 1968 C model is gross 4400 pounds, and the link above indicates that the 1967 B model is 4300 pounds. (landing category)
See attachment, second post on this thread page.
http://www.337skymaster.com/messages...+weight&page=2
Unread 10-25-10, 06:11 PM
The 337E (at least mine) is the same as the 337F, namely 4630 take off and 4400 landing.
Unread 10-25-10, 07:38 PM
It doesn't matter what the limits are in the USAF flight manual, if you are civil licenced. You are required to follow the type certificate data sheet. Data sheet A6CE has this:
C.G. Range (Landing (+137.5) to (+143.3) at 4300 lb.
Gear Extended) (+136.0) to (+143.3) at 3600 lb. or less
Straight line variation between points given
Landing gear retraction moment is +3318 in.-lb.
Empty Wt. C.G. Range None
*Maximum Weight 4300 lb.
No. of Seats 4 standard (2 at +102, 2 at +141), 5-6 optional (1-2 at +170)
Maximum Baggage 365 lb. (Reference weight and balance for additional information)
Your maximum weight is 4300 lbs.
The USAF flight manual lists all weight in excess of 4400lbs must be jettisonable, which means loaded on the wing pylons, and each pylon is limited to 350 lbs.
I don't know if the civil aviation authorities in Australia follow the USA FAA TCDS's.
Unread 10-26-10, 09:07 AM
ConwayB's Avatar
Thanks to one and all
Hello all,
Thanks for all your replies.
I actually located the Type Data Sheet and obtained that information, Skymstr O2, just today... so thank you none-the-less.
For some unknown reason, the weight and balance guys gave the aircraft a MTOW of 1950 kilograms which is 4290 lbs! They robbed me of 10 lbs!
Herb, thanks for the post on the performance. I have that POH. Don Nieser got it for my O-2 purchase because our regulator won't accept the O-2 USAF flight manual, so I have to use the civilian manual. That's one of the reasons why I had the question; because it refers to 4400 lbs!
Oh well, even though the O-2 was flown at 4850 lbs... I guess I'll have to stick to 4290 lbs.
Once again, thanks to all.
PS. I'll post some pics of the glass cockpit I've had put into the machine. 1968 O-2 on the outside, 21st Century on the inside. Can't wait to get it in the air!
Cheers
Conway
