Unread 08-16-09, 11:04 PM
Oil Level Sensor
I've been investigating a product for Aircraft Extras allowing you to place a sensor in the bottom of the oil pan and alert the pilot when the oil level becomes low (around 4 quarts). If I started out with a normal amount on oil on a cross country trip and the sensor went off, I would be looking for a place to land right away. The sensor can be place in the drain holes. The problem I see is the lack of clearance between the nose wheel and drain plug in the front and dealing with oil drains in the rear. It is blocked by the muffler and pulling the sensor all the way out while trying to drain would be a mess. My question:
1. Is there another port on the oil pan for this purpose? (The sensor was designed for Lycoming and it looks like they have couple)
2. Is there any type of STC which allows you to place another port on the bottom of your oil pan?
Thanks for any advice,
Karl
FYI, this is the website and scroll down:
www.aircraftextras.com
Unread 08-17-09, 08:06 AM
tropical tropical is offline
First of all if you are going to try to install this in a certified airplane you will need a FAA Field Approval. Good Luck on getting that.
Unread 08-17-09, 10:31 PM
I definatly agree since non of this items are STCed. The only way would be with field approval. I was trying to determine if it could be installed before I talked to the FAA about it. I don't see an easy way to physically install this item, so I'm going to scratch it from my wish list.
Thanks for the input Tropical,
Karl
Unread 08-18-09, 12:12 AM
Let me add my 2 cents worth on why not having it is not a big deal.
First, long before you do damage to the engine due to low oil, the prop will feather. I know of at least two cases where this has happened. Loss of oil, prop feathers (which should lead most of us to look at oil pressure), engine gets shut off, no damage.
Second, you've got two engines, so finding a place to land is not the emergency it is with a single.
If you still want to add a low-oil indicator, it may be a lot easier to install and get a field approval on an oil pressure sensor with warning light that simply connects with a T fiitting to the oil-pressure line that now goes to the oil-pressure gauge.
Unread 08-18-09, 10:29 PM
I know it's not the same thing, but didn't the O-2 have an oil filler system? So that you could add engine oil during flight. They used it to cross the Pacific.
Unread 08-18-09, 11:32 PM
They did have it for the ferry flights, but I don't know that it was part of the standard equipment and retained after they got to Vietnam.
For those of you who don't know the story, it was the in-flight oil filling that caused the only ditching in the many aircraft ferried from the U.S. to Vietnam.
Cessna and/or Continental had calculated/estimated the amount of oil burned per hour by these new engines on these very long flights and instituted a procedure for in-flight refilling. One of these aircraft had one engine that, by sheer luck, had an impossibly perfect set of tolerances and burned much less oil, so the refilling led to excess oil, plug fouling and engine stoppage. Because the aircraft was so overweight with additional fuel for the trip, the remaining engine was unable to maintain altitude and the aircraft was ditched. The pilot was rescued.
