Unread 02-05-05, 06:02 PM
Exhaust pipe assy-turbine
I need a pipe assembly - turbine PART NUMBER 1-555-06 - 27
New or used. If you know where I can get one please post it.
Jerry
N34EC
Unread 02-06-05, 01:29 PM
SkyKing SkyKing is offline
More infor please...
Jerry,
I was trying to cross check the part number you gave in the Numerical Index but cannot locate... are you sure you have the right part number? And is this the exhaust stack for the front or rear, or something else entirely?
PS... Receieved your e-mail and will respond later.
SkyKing
Unread 02-06-05, 01:38 PM
ERROR!
I see the problem now... wrong part number. If you're talking about Item #1 for Figure 82 (Serial P337001 thru P337225), then the correct part number is 1555006-27 "Pipe Assembly-Turbine LH) for the rear engine.
Can the old one be repaired? This item appears to be welded in many places already.
BTW, the piping on the Serial range P337226 & On in Figure 82A is one of the reasons I looked for a later model... just didn't like all the extra stuff that Cessna 'imagineered' into that little rascal! Too many extra clamps, screws, nuts, and odd piping materials. Compare the two figures and see what I mean.
SkyKing
Unread 02-06-05, 01:49 PM
pipe assy
Hello SkyKing, Sorry about part number, It is 1555006-27.
We tried welding but skin too thin. Keeps burning more off as we try to weld.
I'l await your other e-mail.
Cheers
Jerry
Unread 02-06-05, 03:58 PM
One of the major listed exhaust component rebuilders in Trade-A-Plane... and the name escapes me just now... they can probably repair to new specs by splicing an overlay sleeve, or what-have-you. That's probaby your BETTER and wisest move at this point before the ham-fisters ruin it.
SkyKing
Unread 02-06-05, 08:32 PM
Jerry
Try Acorn welding 1-888-388-8803
Kim
Unread 02-08-05, 04:56 PM
Thanks guys, I'l check them out.
Jerry
