Unread 08-04-04, 01:04 PM
Talking Cowl Flap Motors
I am working on an STC to offer a replacement motor for the current cowl flap motors used on the Skymaster. Expected sell price for a new motor including gear head is between $800.00 and $1200.00 depending on initial quanities I have manufactured. I am surveying all to determine the interest and how many should be made on the first production run. I would appreciate your feed back.
Cheers
Jerry De Santis
Jetech Inc
N34EC
Unread 08-05-04, 08:01 AM
Is this going to be a sealed unit? One of the biggest failure modes is contamination, usually from washing down the engine compartment. Oh, cart before the horse, is it electric, or hydraulic? I always thought hydraulic would be a better system.
As you know, Owen sells replacement units. More expensive, however.
Unread 08-05-04, 10:29 AM
DHatfield DHatfield is offline
DHatfield is an unknown quantity at this point
Jerry,
Are they interchangeable front to rear? I might consider buying a spare to help you with your effort, but since my motors are working now, I don't know if buying two would make sense.
David
Unread 08-05-04, 05:05 PM
motor
Larry, it is a sealed electric 24v motor.
Dave, we are still trying to adpat a brake for use on the rear cowl flaps but as it is at the current time, the first batch will be for the front engine. I will keep you informed.
Cheers
Jerry
Unread 08-06-04, 10:57 AM
Great.
Same limit switches, just a replacement motor? It would be cool to redesign the system, get rid of limit switch bounce. Just a thought.
Unread 08-06-04, 12:56 PM
MTR
Larry, I considered doing away with the limit switches and going to an encoder on the motor but that has some unique problems to solve. To do it right you need at least one limit switch as a home position so that from time to time the encoder can be zeroed out.
Jerry
Unread 08-08-04, 05:23 PM
Don Hickman's Avatar
Don Hickman Don Hickman is offline
Don Hickman is an unknown quantity at this point
As with so many things, it would be great to know that there are alternatives available when the time comes. At the moment, however, both motors are working fine. But the front one quit in May while I was in Mexico. Dead. I had a Mexican mechanic friend of mine look at it and he replaced a diode in it and it works great now. But for how long? Who knows? When it craps out, I'll be calling you!
Unread 03-04-05, 05:29 PM
scade scade is offline
scade is an unknown quantity at this point
Jerry,
What’s the progress on the new motors?
I am interested in buying one when available.
Steve
Unread 03-04-05, 07:15 PM
bsutton bsutton is offline
bsutton is an unknown quantity at this point
Jerry,
I would be interested.
Unread 03-05-05, 04:41 PM
Jerry:
Don't need one right now, but I'm sure it's just a matter of time.
Unread 03-05-05, 08:29 PM
Keven
Jerry:
Interested.
Keven
Gay Video
Unread 03-07-05, 11:52 AM
my rear cowl flap became frozen, we disassembled the motor and removed the
friction clutch disks. they work perfect without the clutch brake. the have never closed in flight , maybe in a extended dive at red line they might
Unread 03-07-05, 12:26 PM
My experience was that the cowl flaps want to open somewhat, not close. At high speed, the motor was straining to get them fully closed. If the brake slipped, they'd creep partially open.
Unread 01-16-06, 03:29 PM
Jerry -
Did you ever complete this motor build?
Unread 01-16-06, 04:36 PM
STC
Hello Pat, I let the ball drop for a bit of time and now back working on it. I will keep all informed as I get to the nex step.
Yap! Your right, no brush should be where the gear is. In fact, I don't know how one of the brushes got to the gear part of the unit. If it is one of the brushes from your motor, don'yt understand how the motor worked at all.
Jerry
