Unread 06-20-02, 12:52 PM
GMAs GMAs is offline
George M. Amthor, Jr.
Post Besides it won't fit in the normal...frame...
The normal asp plane has a narrower cowl in the frt and back... than the turbo ones do.. they are wider by about 3 inches... so you would have to rebuild the plane to make it fit... else get a shoe horn to get it in... what most are doing is looking for the older turbos...planes and then putting in the IO-470 or 520's and forgetting the turbo... they will perform much better at lower alt as well as give about the same service level... while being cheeper to maintain... GMAs
