  #29
Unread 01-10-14, 06:27 PM
Originally Posted by JamesC View Post
For ROP your formula leads to 100 % power at max RPM and MP.
However AA placards 35.3 " MP for takeoff power - was this based on HP dyno measurements or math ?
The engine test stand data confirmed the math! This is a very good "rule of thumb" calculation that can be off a very small amount as other factors do affect the mass airflow. Those differences are insignificant operationally.
Even if there is exhaust back pressure, could the peak cylinder PSI's still not be too high at 37 "MP full rich with the extra O2 from the colder denser intercooler air?
Thanks very much.
Very good question. The answer is "no." Peak ICPs are controlled nicely. The additional FF provided by the fuel controller covers that problem in conjunction with the decreased volumetric efficiency. Mass airflow-type systems like Lycoming's make it a non-issue. The TCM fuel controller handles the increased O2 a different manner, but it works just as well.
Walter Atkinson
Advanced Pilot Seminars
