Unread 02-24-06, 11:52 PM
Roger
Check the nose strut for proper inflation. If it is low on pressure it won't extend all the way and it won't go all the way in the well.
Have had it happen several times on our airplanes. If thats fine look for a broken wire or a bad switch. The main gear up switches ar easy enough to check the nose gear switch is a little harder to get to.
Hope this helps
Kim
