re above
I put in new numbers, however, not sure how to format it. Was tired last night and was 1/2 watching that stupid investigative report on GA accidents on A&E. Very poor reporting making us all look like idiots (maybe there is some truth to that).
I have the table on an excel spread sheet. Also put in gph values. Tell me how to insert a formatted text and what format do you use ?
Significance of Full throttle.
These numbers are transposed from the TCM tables. Say you want 70% power you adjust throttle to 13.7 gph and if you lean to peak you should be 3 gph less. Just a quick way of getting to the correct fuel flow setting. In this case 50 rop would be 2 gph less. let MP falls where it may. I tend to use 2400 rpm at 68-73% pwer.
OR have I missed something?
Bob
