Oxygen Fill Adapter
Hi Guys,
Every time I want to fill my oxygen system, its a problem. The little recessed area where the fill nozzle is at, on top of the wing at the starbord wing root, prevents a normal fill, because the straight rigid fitting from the fill hose hits the wing to fusalage fairing. Thus, the fairing (and the associated dozens of screws) must be removed, turning a 10 minute job into 45 minutes. Has anyone else had this problem, and what is the solution?
What I need is a 90 degree adapter fitting that I can carry in the plane. Anyone know where to get one?
Ben
