Unread 06-03-05, 05:56 PM
went north this am, worlds fastest 337 stiff leg. checked the fluid, ok. maintenance seems to think the power pack is getting tired, 1700 hrs and the orginal one from 73 with no service. for all the intermittent hapenings with no luck duplication it on jack and all the problems usally vary over that last four years, so out with the old in with the new. gear works and doesn't, hand pump works then it doesn't. maybe internal leaks in the actuators, no visable leaks the only thing that always works are the gear doors (removed the large clam shells).
thank's for the advice will let you know what we find
rick
