three years ago mind did the same thing. after t/o the starter cylnoid stuck on and burned up the starter, boiled the battery and a complete electrical failure, had to pump the gear down. replaced the starter, battery and the cylnoid. mine is a 73p and none of the cylnoids have ever been replaced, after that i changes all three and have never had a problem with them sence. these cylnoids as they get old start to stick, they are only 30.00 and very easy to chang out. also sometimes the alt circuit board get old, corrorded and can even crack with will cause intermittent elect. problems, wear down the batt give gear problems and finally break the alt coulp, had that happen too. this fleet is really starting to age so don't be supprised what can crop up.
