Unread 04-29-02, 08:25 PM
Bob Cook Bob Cook is offline
Treasure Cay Rendezvous
For those that are flying....... (posted on Peter's UNO board as well)
1) need to file an ICAO flight plan. Miami FSS handle these better than others. File with them if you do not use duats of Flightstar.
2) Will not give you direct above VRB or sometime MLB.
3) std routing is via BR62 to ZFP if coming from north.
4) fuel at Marsh Harbour or MYGB is 3.10 / US Gallon.
5) Okachobee has best fuel price. around 1.50.
6) life jackets avail at FPR VRB PBI.
7) remember tie down ropes!
8) If you have it bring a cable lock or prop lock.
9) need 1.5 hrs min fuel at MYAT for return to FPR using ZFP / BR62/L / ANGEE / dir FPR. (prefered routing).
10) can go direct on return to ANGEE but must be above 7k IFR.
11) if on vfr flight plan you can cancel with miami and flight following at 7k on way in to MYAT.
questions email me at bobcook@oii.net or 242 365 8683.
have a safe trip. Wx here is 80 deg. water temp 85 deg. light SE winds at 5 knots with 60% humidity.
Bob
note for those not coming;
I will take lots of pics and pass them to Kevin for posting. We will make sure GMAS is "front and centre".
