Unread 03-06-05, 09:32 PM
Member
Walter:
Yes. This clears up a lot of the questions that I had.
The one thing that I hadn't realized is that your research indicates that operating 50 degrees rich of peak egt at 75% power, per the manufacturers recommendations, actually causes the engines to run in the "red box" because the ICP's are at some level that is objectively "bad"?
Am I understanding you correctly on this one?
