Fred:
It might not be the strainer. It could be the aux fuel pump. I had this happen on my 73 P337. There is a little drain line that is connected to the aux pump. It's purpose is to make sure that if the seals between the electric motor and the pump fail, the fuel is drained away from the motor. These pumps have a TBO recommended by the manufacturer(Dukes). Carefully track down the fuel leak, and the drain lines.
Mark
Mark Hislop
N37E
