Education... again!
Craig,
I hate beating this 'education horse,' but your answers are to be found in the TCM TSIO-360-C, CB "Operator's Manual" in Section V, "Abnormal Enviornmental Conditions" which discusses preheating and operations below freezing. This manual should be with the airplane, but these things tend to be lost over time. Maybe you or the person you're flying for should order up a copy from TCM. The Part Number is X30507. The POH also addresses the issue of cold weather ops, but only briefly in Section 4. There are some other threads regarding and oil cooler cover plate which will help get the oil temp up to speed, especially in your cold country.
Hope this helps.
SkyKing
