Unread 01-25-05, 10:45 AM
Dale Campbell's Avatar
Owner 337H N337DC
Good Luck on making lights stop blinking
I have spent many dollars trying to stop the blinking lights.
I had the parallel system put in. Had both coupling replace on two alternaters. Had one new alternator installed. New battery, all diodes on fire wall replaced in regulators circuit. Some wiring replaced. Some breakers replaced. Each time the A&P said it is ok.
Well each time it was for about 10 hours. Then the lights start the blinking again. It does it more when battery is up to full charge. If you turn on a lot of devices to demand more electric power they do not blink as much. But you will never get it to stop for good. I finally gave up and just live with it. Good luck!!! Dale
