DO NOT TRY THIS AT HOME
I did not read your post correctly. This is a Radio, intended to work in a car, right??
The adapter that goes with it will not deliver the correct voltage, and you will burn up the radio.
You need a seperate voltage dropping unit, not something you can plug into the cigarette lighter circuit.
