Thanks for replying, Mark.
Yes, you're right about needing only one Electronics International UBG-16. I misstated the case.
The UBG-16 can display all EGTs and all CHTs for both engines. It can also display oil temperatures and pressures. And it has an option for a warning played through the headset whenever any temperature or pressure limit is violated.
The Insight Gemini 1200 or the JPI Twin will do the job nicely, but they don't have the oil pressure and oil temperature feature or the aural warning option.
I'm still hoping a 337 owner has discovered a way to use the UBG-16.
Best,
Gordon
